It is currently Mon Aug 11, 2025 11:21 pm
PostPosted: Mon Mar 28, 2016 9:42 am
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
I would like to start removing the neck and bridge of my build just to get things moving along while I put together my space to build. my question...can start doing this in an uncontrolled environment? I was thinking I could keep my case somewhat controlled and store the guitar in there when i'm not working on it. I don't plan on doing any glue work until I have my space but would like to get a jump on it all.
good or bad idea?
also....whats an easy way to measure my deflection on the top? I think its probably a good idea to know this before pulling the bridge lol.
PostPosted: Mon Mar 28, 2016 9:52 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
It sound like the guitar is already built so other than treating the guitar properly with regard to humidity, I see no difference with having the neck and bridge on or off while putting together your work space.
I spent about 45 minutes on Friday and built this deflection jig from parts I had laying around in my shop. I just set it on the edges of the lower bout and add weight. Just for safety I use soft diving weight for a load. I could imagine somehow spilling a hard 5 lb weight on my top.
These users thanked the author johnparchem for the post: DannyV (Mon Apr 04, 2016 8:22 am)
PostPosted: Sun Apr 03, 2016 11:16 am
Last Name: coleman
City: rome
State: ny
PostPosted: Sun Apr 03, 2016 11:17 am
Last Name: coleman
City: rome
State: ny
I got it apart very cleanly. Sanded the top back to new. Next step is to see if I can't get the cracks in the back fixed
PostPosted: Sun Apr 03, 2016 6:36 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
John, how do you spread out the load a little on your top so that the indicator probe doesn't dent your top? I suppose you could let it push on a small block or coin; something of that nature to spread the 5 pounds over a little area,
PostPosted: Sun Apr 03, 2016 6:42 pm
Last Name: Parchem
City: Seattle
State: Wa
Good point! I just made it last week. On just a top I will probably just use a small piece of wood. My plan for the tool first off was to measure my completed guitars on the bridge to start to make some long term observations.
PostPosted: Sun Apr 03, 2016 9:05 pm
Last Name: Imbler
State: KS
Oh, that makes sense. I didn't think about measuring at the bridge. I'll be interested to hear if top deflection correlates well with resonance frequency when you get around to your existing guitars. I just measure the body resonance on my latest which sounds more open and louder than the others, and it is about a half step lower than my others,
PostPosted: Wed Apr 06, 2016 10:21 am
Last Name: coleman
City: rome
State: ny
Before
Last Name: coleman
City: rome
State: ny
After
PostPosted: Wed Apr 06, 2016 10:23 am
Last Name: coleman
City: rome
State: ny
Thank god I got them somewhat back together!
I should've able to push it up in spots from underneath and pull it together from the sides and CA it together. Thoughts?
PostPosted: Wed Apr 06, 2016 10:57 am
I did one similar to that although it was in multiple pieces although the guitar was falling apart so I went ahead and took the back off. Got it glued back together and then put some cleats on it. There are some gaps that will have to be filled when it is time to refinish it.
PostPosted: Wed Apr 06, 2016 12:29 pm
Last Name: coleman
City: rome
State: ny
Nice work.
I really don't want to take the back off because I'd like to keep the original binding so i'm gonna try to do it with it on. It will be French polish when all is said and done. I'm thinking any imperfections can be filled during finish. I do have a brace to fix though. Any thought on that? Maybe add the missing piece?
PostPosted: Wed Apr 06, 2016 12:33 pm
Last Name: coleman
City: rome
State: ny
PostPosted: Wed Apr 06, 2016 1:29 pm
No, I wouldn't remove the back on yours. I only removed mine because it was mostly off anyway and was in really bad shape.
I would probably want to replace the brace but have not tried to do that in a closed box yet. Hopefully someone with more experience will jump in here.
Users browsing this forum: No registered users and 44 guests
